Main > Main Forum
Cocktail Plans
Blakey:
I couldn't agree more. I spent months with CAD drafting mine, and there were still things I forgot to account for.
I intended mine to fit a 17" PC monitor with a case, but ended up decasing it for better mounting, and gained some precious space.
--- Quote from: ericball on June 24, 2004, 10:40:55 am ---Unless you are building a reproduction build your cab to fit your monitor/TV/tube!
And don't rush your design. Design time is cheap in comparison to materials.
Jkawch:
Thanks for all the help everyone. Blakey your cab is looking nectar, metal cp's plus chrome t-molding add a great touch.
Your CAD files are actually a great help, I have to expand mine a bit though, since Ive got a 19" Happs SVGA sitting here, and I think Ill need some extra room.
I like the idea of expanding the side panels out to 'wings' for the horizontal CP. I need some extra room for my vertical CP's though, because I plan on plopping an extra 4-way j-stik along with what you have on there.
I hope Im not treading into overkill territory...only time will tell.
Blakey:
--- Quote from: Jkawch on June 25, 2004, 01:44:15 am ---Thanks for all the help everyone. Blakey your cab is looking nectar, metal cp's plus chrome t-molding add a great touch.
I don't understand some of your adjectives! countache, nectar? Are you French-Canuck or speaking a lingo that hasn't reached Australia yet (wish I could say the same for nizzle shizzling)
Mine would probably fit a 19" if the chassis was located separately. Measure up and see. Then change the plans to fit it.
If you want big vert CP's, check out Tilz's cab, and make the panels interlock. Stronger and bigger CP's.
Jkawch:
Dont worry Blakey; countache, nectar...its all honeycomb...just sugar coat it. (Its all good ;D).
Looking for Tilz...couldnt find his cab in the examples or his name on the members list...am I missing something?
Tilzs:
I'm here, Click my www link
