Author Topic: wieght of a coin box  (Read 828 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« on: June 23, 2004, 03:43:55 pm »
how much does a coin box wieght for over/under happ coin box approx?
thanks .. can't find weight anywhere on happ site
sirwoogie
  • Supreme Chancellor
  • Last login:April 12, 2024, 10:16:38 pm
  • It's Hollyfeld in a Winnebago!
Re:wieght of a coin box
« Reply #1 on: June 23, 2004, 04:24:17 pm »
Which model of over/under coin door, and which configuration?
mcdo15
« Reply #2 on: June 23, 2004, 04:26:11 pm »
your typical starndard one..found on must machine...  two type of windows, coin box, 2 mechs..  meassures about 8 by 20 inches...
item number 40-0038-00
it's called over/under door
« Last Edit: June 23, 2004, 04:27:22 pm by mcdo15 »
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #3 on: June 23, 2004, 04:35:09 pm »
Are you asking for the weight of the entire door, or just the plastic coin box that collects the coins?
The door will weigh a little under 15 lbs, if you want to know the weight on the coin box, I can weigh one when I get home tonight.
mcdo15
« Reply #4 on: June 23, 2004, 04:51:10 pm »
not needed..thank you..i will estimate it at 20 lbs then (comes with coin box)
thank you
sirwoogie
« Reply #5 on: June 23, 2004, 04:58:41 pm »
Going to disagree with you there :)
Check: http://www.happcontrols.com/coindoors/doors.htm
As you can see, there is a wide array of configurations and options to the Happ coindoor models.
Alas, I do not have the model you are looking at. :-\ I have door #40-0946-20 (Multi-Player Over/Under Door - 2 Player) and its associated accessories. I can still weigh that if you want.
mcdo15
« Reply #6 on: June 23, 2004, 06:03:15 pm »
i listed the part number above..sorry for in confusions..didn't realize the rest of them had similar names
i was trying to find shipping cost. (won auction)
