Main > Main Forum
Happ's Perfect 360 -- Feels VERY stiff?
sofakng:
Hmmm!
I've checked the size and they did in fact send me the 5/8" sleeve. They are sending me the correct parts.
They also said I was second person today to call for this problem. Did somebody else from this forum call them about this? =)
NoOne=NBA=:
--- Quote from: sofakng on July 08, 2004, 04:05:17 pm ---My only concern is that the p360's becoming less acurate because of the looser spring...
This shouldn't be an issue unless the spring moves the stick from center for some reason.
As long as the spring is approximately the same diameter, and length, you should be fine.
All the position sensing, and thus the accuracy, is done optically.
Spring strength shouldn't have any effect on this.
ChoboPants:
sofakng...did you say something special cause after talking to about 6 people they gave me an RMA number and I have to send it back and wait for a new one >:(
I kept telling them that my friend called just yesterday about his and they are sending him the correct part now but they wouldn't listen. It better have the right length sleeve this time :-\.
Also...does anyone know anything SOLID about wiring this to a dreamcast. I have a MAS stick and everyone just says "wire it to the +5v coming in from the DC" but my multimeter definitely says only +3.5 volts are coming in and after hooking it up there is no connection on the DC.
TalkingOctopus:
--- Quote from: ChoboPants on July 09, 2004, 02:33:41 pm ---sofakng...did you say something special cause after talking to about 6 people they gave me an RMA number and I have to send it back and wait for a new one >:(
I have a Happ P360 hooked up to a dreamcast. Use the blue wire coming out of the controller cord as a 5 v source. You can use the same ground that you use for everything else.
sofakng:
Hmmm, I didn't really say anything special. When I first called they transfer me to customer service, then they transfered me to sales department (??).
The lady I spoke with a spanish accent (sp) and didn't give me a hard time about it. I did speak (a few weeks ago when the p360's were sold out) with my regional sales associate. I'm not sure if he pulled any strings but he sure was helpful.
*shrug*
You might want to contact your regional sales associate as well. Who knows, it might be helpful =)
