Author Topic: How did you mount your Oscar Controls Mouse Hack?  (Read 593 times)
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« on: June 22, 2004, 12:44:13 pm »
I just got an Oscar Controls mouse hack for my Happ Trackball and am wondering how to mount the board so it's not flailing about inside my trackball panel.  Any suggestions?  There are some very small holes through the board I bet were used to hold it in place but I think finding screws long enough or thick enough to hold it in place would be pretty difficult.
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
delta88
  • Last login:April 22, 2022, 09:53:16 pm
  • This place is still here?
Re:How did you mount your Oscar Controls Mouse Hack?
« Reply #1 on: June 22, 2004, 12:45:52 pm »
I zipped ties it and then zipped it to something else. could always wrap in in a static bag ir bubble wrap and tape it up as well.
sall good ;)
simplygriff
    • simplygriff.com
« Reply #2 on: June 22, 2004, 01:10:05 pm »
There's an idea.  I hadn't thought of that.
Any other solutions?
-G
www.simplygriff.com
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: June 22, 2004, 02:02:59 pm »
i didn't mount it IN the trackball... I mounted it outside with standoffs or something screwed into the control panel wood... I think.. it's been ages since i've looked under there.
rampy
NoOne=NBA=
« Reply #4 on: June 22, 2004, 02:04:17 pm »
I mounted mine in a project box with the input cables coming out one side, and the USB cable coming out the other.
The actual mouse hack part is just thrown in loose, with cable restrictors on both cables, so that it doesn't get pulled on.
simplygriff
    • simplygriff.com
« Reply #5 on: June 22, 2004, 02:21:05 pm »
rampy
I guess I should have clarified.   :-\I'm not trying to mount it in the trackball but in a removable trackball panel that is part of my CP.  Basically a big box seperate from my joysticks that will act as a mouse.
Where did you get your standoffs?  Did you hack them out of a mouse or did you make them?  And what kind of screws did you use?  Thanks!
www.simplygriff.com
« Reply #6 on: June 22, 2004, 03:12:38 pm »
sall good ;)
Someone mentioned before that mounting circuits in anti-static bubble-wrap is bad...apparently the stuff can *conduct* electricity...
simplygriff
    • simplygriff.com
« Reply #7 on: June 22, 2004, 03:22:23 pm »
That didn't sound like such a good idea to begin with.
-G
www.simplygriff.com
