Author Topic: Question: Mounting Hard Drive and Power Supply  (Read 1624 times)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« on: June 22, 2004, 10:27:04 am »
All,
I want to mount my Motherboard, power supply, hard drive in my cabinet with out the case.  What is the best way to attach the hard drive and power supply to the side or bottom of the cabinet?
Thanks,
Todd
SirPeale
  • Green Mountain Man
Re:Question: Mounting Hard Drive and Power Supply
« Reply #1 on: June 22, 2004, 10:33:52 am »
Bend some sheet metal to make a drive cage.
For the PS, angle brackets.
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #2 on: June 22, 2004, 10:44:47 am »
try cutting out a harddrive cage from an old AT case, as for the power supply, just get a small piece of plywood, mount the power supply to that, then mount the piece of plywood to your cab
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #3 on: June 22, 2004, 11:00:31 am »
 I've been able to use 3.5" to 5" drive mounting kits ($5 at Fry's, etc) to mount in a cab. I'm referring to the solid kit not the one that resembles 2 spaced drive rails.
-Goz
lokki
  • Last login:June 29, 2017, 12:57:48 pm
« Reply #4 on: June 22, 2004, 11:40:21 am »
Hi,
I used a very low tech (inexpensive way) to mount the HD on my cab.
Used Plumber's tape... Strapping tape (metal or plastic)
(around $2.00)
http://www.plumbingworld.com/tapes.html
« Reply #5 on: June 22, 2004, 11:46:47 am »
I held my PSU down with screws, thru existing holes.
My HDD is mounted on it's side, using one of those bracket things which make a 3.5" drive fit in a bigger drive space.  Just screwed using existing holes again.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #6 on: June 22, 2004, 12:51:33 pm »
Heck I used angle brackets for my drives too.
