Author Topic: Nintendo Blue - result pics  (Read 3537 times)
pcates
  • Last login:January 05, 2011, 08:15:57 pm
« on: June 19, 2004, 11:38:56 pm »
I am restoring an old Donkey Kong. Does antone know what kind (gloss, semi-gloss, spray, etc...)of paint and color to get. Or is it best to just bring in a chip to match at the paint shop?
thanks, Patrick
« Last Edit: June 28, 2004, 11:46:23 pm by pcates »
koolmoecraig
    • My Intervention
Re:Nintendo Blue
« Reply #1 on: June 20, 2004, 04:00:45 am »
Don't even think about spray paint. It will turn out like crap. Unless you have a professional spray gun of some sort.
Take a paint chip to color match, and buy some good primer.
I repainted my Q*Bert using a FOAM roller with lots of fine sanding between coats. It turned out very sweet. You could not tell that it is not laminate.
Take your time and do it right. Sand down to the wood, primer it, sand, paint, sand, paint, sand, and paint.
Peace,
Craig
MameMe
  • Last login:June 08, 2005, 06:45:25 am
Re:Nintendo Blue
« Reply #2 on: June 20, 2004, 07:10:35 am »
Arcadiac painted his cab Donkey Kong blue, here are the specs...
The paint itself is Behr Premium Plus Int/Ext Hi-Gloss Enamel no.8600
the Home Depot MIX tag says:
______________________________________
COLORANT            OZ  48  96
THALO GREEN          0      3    1
THALO BLUE            3    18    0
EXTERIOR RE            0      3    1
Jakobud
  • Last login:May 05, 2024, 10:53:37 am
Re:Nintendo Blue
« Reply #3 on: June 20, 2004, 04:25:45 pm »
Here are color codes from Apollo's website:
http://www.appolo.com/colorcodes/donkey_kong_blue.htm
1 Gallon - True Value Paint
Base: EZS-D (Incand.)
Int. Latex/Semi-Gloss EZ Kare
Colorant  Amount
D             2Y32
E             3Y36.5
V             31.5
For the black trim, coin door and marquee holders on both DK and DKJr I just used satin black rustoleum spray paint.
pcates
Re:Nintendo Blue
« Reply #4 on: June 21, 2004, 01:22:20 am »
Thanks.... I'll post my results when its done.
G@M3FR3@K
  • Last login:December 31, 2015, 12:20:28 am
Re:Nintendo Blue
« Reply #5 on: June 21, 2004, 04:55:26 pm »
This Original Arcade Cabinet Paint Tips and Codes may be of some interest to anyone trying to find the right shade (tint) of color for their original/replica arcade cabinet.
According to this guide the Donkey Kong Blue posted at Appolo.com is too dark and in the wrong hue.
However, since there is no accurate color yet sampled in this giude the Appolo color code is probably your best bet, unless you take a sample (paint chip) of an original DK to your local paint/hardware store and get them to match it for you.
Best of luck!  And be sure to post some pics of your cab when you're finished. :)
« Last Edit: June 21, 2004, 04:57:05 pm by G@M3FR3@K »
pcates
Re:Nintendo Blue
« Reply #6 on: June 28, 2004, 03:27:19 pm »
I used Lowes Enterprise Semi Gloss oil based paint (same kind as others used on Brian's Arcade site). They matched a piece of laminate that chipped off the cab to this:
Base 4-1134
added colors:
 101 -1 shot
 102 -25 shots
 103 -7 shots
 113 -2 ounces, 13 shots, 1 half shot
I think it matches quite well :) , just not sure what kind of brush to use so I do not get all the brush marks. Might try to lightly sand then add another coat. In the pic I have painted the right most part of the cab.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:Nintendo Blue
« Reply #7 on: June 29, 2004, 09:19:20 pm »
Brush?? Why not a roller?
NO MORE!!
Ken Layton
  • Guru
  • Technician
Re:Nintendo Blue - result pics
« Reply #8 on: June 30, 2004, 12:01:30 am »
Donkey Kong, as was most Nintendo cabinets was finished in Formica laminate and not painted. Paint does not stick to Formica. It scratches right off.
Apollo
    • Eight Bells
« Reply #9 on: June 30, 2004, 12:33:11 am »
By the way that's not my site.
pcates
Re:Nintendo Blue - finished
« Reply #10 on: July 12, 2004, 09:54:28 am »
I finished the paint job, and I think I have a nice match. The bottom of the cabinet around the coin door has not been painted, the rest has. Check out the pics I think it came out great...
pcates
Re:Nintendo Blue - another
« Reply #11 on: July 12, 2004, 10:05:42 am »
pcates
Re:Nintendo Blue - last
« Reply #12 on: July 12, 2004, 10:08:09 am »
blacktiger
  • Last login:May 13, 2006, 03:59:38 am
  • My name is Mike and I approve this message.
« Reply #13 on: July 12, 2004, 10:34:22 am »
Excellent job!!! :o
Games Working: Pac-Man (Dedicated), Centepede cocktail (Dedicated), X-Men, Mortal Kombat, Street Fighter 2, Magic Sword, Rolling Thunder, Gauntlet (Dedicated), NBA Jam TE (Dedicated)  DK,  Pharaoh Pin
