Author Topic: C-Clip? E-Clip?  (Read 2520 times)
tj
  • Last login:June 18, 2004, 12:37:14 pm
C-Clip? E-Clip?
« on: June 19, 2004, 01:30:51 pm »
I've heard it called a few names, but whatever it is, I'm having trouble getting it installed on my X-Gaming joysticks.  With a little work, I can slide it on partially, but no matter how hard I push, I can't get it all the way around the rod.  Am I even supposed to be sliding it on?  I'd hope I don't have to hurt my fingers to get this on, but at the moment they hurt and the c-clips are still off.
Witchboard
Re:C-Clip? E-Clip?
« Reply #1 on: June 19, 2004, 01:38:50 pm »
You should be using some needle nose pliers.  At least, that's how I get mine off and on.
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
Re:C-Clip? E-Clip?
« Reply #2 on: June 19, 2004, 01:40:02 pm »
They slide on.  Use a screwdriver or something to slide it on rather than your fingers.  The clips are very annoying though.  One time, when I took the e-clip off my P360 joystick, it flew across the room and I had to spend a half hour looking for it.  :-\
tj
Re:C-Clip? E-Clip?
« Reply #3 on: June 19, 2004, 01:45:29 pm »
Thanks.  Once I get it on a little way, can I stop pushing down on the other piece (the little piece that flips for 4/8 way?)  Or do I have to keep putting pressure on that?
spystyle
Re:C-Clip? E-Clip?
« Reply #4 on: June 19, 2004, 03:22:03 pm »
I also use needle nose pliers.
Dig it ?
Craig
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re:C-Clip? E-Clip?
« Reply #5 on: June 19, 2004, 07:21:46 pm »
I'm not calling you an idiot, but are you putting it on the rod or in the groove on the rod?
tj
Re:C-Clip? E-Clip?
« Reply #6 on: June 19, 2004, 08:17:57 pm »
Hehe, it's okay, I am an idiot.  I'm putting it in the groove though, so I guess I can't be that bad.  I finally got it on, after trying for a few minutes with a screw driver, then got it on the rest of the way with the pliers.  Thanks for the help.
