Main > Main Forum
Software choice to design?
Pages: << < (2/2)
Tahnok:
--- Quote from: DaveMMR on June 18, 2004, 05:24:29 pm ---is the marquee supposed to be the same height as my eyes on this 6 foot 2 inch body of mine?
Yes, yes it is. I had the exact same thought when I was planning and cutting mine. The machine looks bigger though when the entire thing is put together.
Sylentwulf:
This might be a completely useless post, but hopefully someone knows what I'm thinking of...
I used Visio personally, but if I hadn't, there is a free online control panel design thingy (Flash, java, web enabled, something) online that I thought was VERY well done, and would recommend it..... if I knew where it was or what it was called..
A little help here?
talem:
--- Quote from: chrisindfw on June 18, 2004, 03:36:22 pm ---Ok.. Other than Visio and AutoCad.. What software did/would you use to plan and build your cab?
I am looking for something where I can visually put the pieces together before messing up 100 pieces of wood. :)
3d studio max? o.o  um other than that all the other autocad type proggys are like $300
Nefesis:
--- Quote from: Sylentwulf on June 19, 2004, 07:44:23 pm ---This might be a completely useless post, but hopefully someone knows what I'm thinking of...
A little help here?
do you mean the interactive control panel design available at: http://www.move360media.com/mame/icpd/Launch.htm  ?
Sylentwulf:
--- Quote from: Nefesis on June 19, 2004, 08:43:54 pm ---do you mean the interactive control panel design available at: http://www.move360media.com/mame/icpd/Launch.htm  ?
That's it, thanx :)
Pages: << < (2/2)
Go to full version
