Main > Software Forum
Which Gentoo kernel?
Pages: << < (3/3)
barvaz:
Which kernel are you using?
Did you compile the kernel with
whammoed:
i compiled event interface into kernel and did cat /dev/input/event1 and got junk on the screen but still no luck with advmame.  Have you actually got it to work?  I noticed I had to install kde before advmame would work.  Gave some oslang error before i installed kde.  suppose it installs something that advmame needs.  when i use advm i get:
unable to initialize the mouse driver.  the errors are:
event: no mouse found
raw: no mouse found
seibu:
Hmm. Remember that if AdvanceMAME is running using the svgalib, then mouse support for the svgalib needs to be set up. If it's using X, then mouse support in X needs to be set up.
I believe there is a command line operator you need to use if you want mouse support using svgalib. Sorry, I don't have it to hand. It was mentioned on this forum, or the forums at http://www.mameworld.info/ubbthreads/ubbthreads.php?Cat=
Sorry to be so vague, but this may give you a lead...
Pages: << < (3/3)
Go to full version
