Author Topic: How long can wires be between buttons and IPAC?  (Read 1036 times)
jagnogg
  • Last login:November 03, 2006, 01:43:21 pm
  • I'm not wearing any pants.
« on: June 17, 2004, 11:18:18 am »
Would 10 feet be too long?
And which would be better for longer distances - 18 gauge or 22 gauge wire?
« Last Edit: June 17, 2004, 11:25:43 am by jagnogg »
Tiger-Heli
    • Tiger-Heli
Re:How long can wires be between buttons and IPAC?
« Reply #1 on: June 17, 2004, 12:46:34 pm »
Doubtful - There are several people building laptop controllers with printer cables (DB-25) that long or longer.  If you go that route, I've heard it's recommended to also connect the shield ground of the cable to the I-PAC ground terminal.
Theoretically, thicker (18 gauge) wire will have less signal loss.  Realistically, DB25 cable has something like 28 gauge internal wiring, so I don't think it matters.
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #2 on: June 17, 2004, 01:17:43 pm »
Yea, you should should be fine either way.  If you are really worried about it, go with the 18 gauge wire to play it safe.
Still in the collecting parts and ideas phase of cabinet building.
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: June 17, 2004, 01:36:58 pm »
can i ask why 10 feet of wire between ipac and buttons is nessesary?
jagnogg
« Reply #4 on: June 17, 2004, 02:29:59 pm »
I'm using an IPAC in my skeeball project, and some of the controls (start button, buttons to enter initials, coin mech, etc) will be down at the end of the ramp, which is pretty long.
I'm using a very old PC and a 15 inch monitor to keep score since the machine I bought had no electronic components ($75 on ebay :). I'm writing some custom games in addition to having the traditional scoring system.
Here's my web site, where I'll post my progress:
http://tinyurl.com/2kekr
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #5 on: June 17, 2004, 02:36:59 pm »
Did you build that skee ball or found one?  Just curious as it wouldn't be that hard to make your own skee ball, just need to know how to make the smooth jump S-curve transition.
The bigger the gause the better for that length I'd think.  But either way you should be fine.  I've seen long wiring in an arcade cabinet to run the wire along the edges neatly.
« Last Edit: June 17, 2004, 02:39:47 pm by SirPoonga »
jagnogg
« Reply #6 on: June 17, 2004, 02:45:43 pm »
I got lucky and found one on Ebay for local pickup only. I plan on posting measurements of the machine on the site eventually, as people were asking for them in a previous thread.
SirPoonga
  • Puck'em Up
« Reply #7 on: June 17, 2004, 02:48:59 pm »
Cool, can't wait, I just want to know how to make that curve, it wouldn't be hard to make your own after you get that.
