Author Topic: TECH - (FAQ?) - Marquee Light Fixture Eating Bulbs  (Read 1150 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: June 16, 2004, 12:42:44 pm »
Flourescent Light fixture on a Moon Patrol eats bulbs!  When I power up the
bulb flashes a bunch of times and burns up.  Is there a usuall reason for
this?  Thanks, James
Ken Layton
  • Guru
  • Technician
Re:TECH - (FAQ?) - Marquee Light Fixture Eating Bulbs
« Reply #1 on: June 16, 2004, 12:45:37 pm »
Assuming you changed the starter also when you replaced the fluorescent tube I would say your ballast is shot. When that happens it usually takes out the new tube AND starter with it. Buy a new ballast, tube, and starter.
RetroJames
« Reply #2 on: June 16, 2004, 01:02:50 pm »
What are the important specs to know in matching the ballast when I buy a new one?
SirPeale
  • Green Mountain Man
« Reply #3 on: June 16, 2004, 01:22:54 pm »
Would it be cheaper to just get a new assembly?
jcoleman
  • Last login:April 23, 2024, 09:05:19 pm
  • RTFM
« Reply #4 on: June 16, 2004, 01:33:08 pm »
A new 18" lamp fixture can be found for less than $10 at Target or Wal-Mart.
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #5 on: June 16, 2004, 02:19:51 pm »
I got a G.E. fluorescent light unit including the bulb at Wal-Mart for $7.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
MonitorGuru
« Reply #6 on: June 16, 2004, 02:59:35 pm »
It could be the starter or ballast (transformer).   Starters are dirt cheap. Start with that.  49 cents at most stores.  FS-2 if it's an 18" fixture
As far as a ballast, Home Depot carries an IDENTICAL part number for most arcade games. It's a GE one for 14 to 20 watt fixtures.  I've seen others by Sylvania that are a bit larger/heavier that will work with that range to a bit larger. I havn't tried those yet.
Price: $3.59 on clearance at HD for the GE.  Or $2.89 at some places for the Sylvania.
Make sure you get one that works with a Size T8 (8/8th of an inch or 1" diameter), 18" and 15 watts.  Don't go too high or you will risk fire or instant tube blowout.
Oh and *some* of those cheap all-in-one fixtures do not feature immediate (auto) start. You must hold a switch into a separate position which temporarily applies more volts to warm the filaments/tube up prior to starting before the ballast takes over to keep them running at a lower voltage.
Therefore they wont work in game units if you want it to turn on the marquee immediately without first having to hold down a button (behind the marquee :( )
« Last Edit: June 16, 2004, 03:09:41 pm by MonitorGuru »
RandyT
  • Last login:Yesterday at 12:12:44 pm
    • GroovyGameGear.com
« Reply #7 on: June 16, 2004, 09:01:04 pm »
It's a good thing to look out for, but the last few of these I purchased just had normal on/off rockers or slides.
I think it was even listed on the packaging as one of the "features" of the fixture.
The best $7 you can spend, IMHO, as I have had one of these on 24/7 for over a year and it's still going  :)
RandyT
