Main > Software Forum
Anyone explain Visual Pinball?
Chris:
Probably a good moment to blatantly plug an original table I've created with Visual Pinball called "Fight Night"... it can be found at http://webpages.charter.net/celamantia/vp .
For people into really old stuff, I also have World's Fair Jigsaw (Rock-Ola, 1933):
--Chris
Demon-Seed:
C:/VPinMAME/Music
Ok I installed the music into H:/pinmame/Music and unzipped as per instructions.
Still DOESNT work.
If it is a visual Pinaball game and not pinmame (uses roms) u put the music into your visual pinball directory not pinmame.
ie) H:/visualpinball/Music
then it works! FYI
JoeB:
The install instructions are a bit wrong on the visual pinball web site.
A better way to install it is:
C:\VisualPinball (rather than C:\Program Files\...)
C:\VisualPinball\pinMAME
The actual tables do not go into the pinMAME subdirectory (tables) but rather the tables subdirectory of VisualPinball!!! Thing of pinMAME as a component of visualpinball. You play visual pinball (it's the thing that puts everything together, so all the files are in subdirectories of it..)
- Tables is subdirectory of VisualPinball
- Music is subdirectory of VisualPinball
- Rom is subdirectory of pinMAME <-- you need it to get the actual writing on the screen emulated.
Hope this helps.. I was confused about it at first as well!!
