Main > Main Forum
Cutting wood using templates or manually drawn
Pages: << < (3/3)
brained:
humm...
I think i'm just going to draw them instead. Anyways it cant be that hard!! ;).
hyiu:
ohhh... sorry.. misunderstood your question...
for the rest of the cab... I just measured the wood and draw on it and cut..... did not print it out and tape it on the wood....
(wasting too much paper....)
but I guess if you buy those full size paper template... it's also cool....
either way... the other pieces are not that hard to cut.... (just the outline anyway.... so... its good with or without paper...)
fredster:
I just use a paper template.  It's for holes. So all you have to do is take a small drill (1/8)  or a nail and mark the center of the hole.
Drill thru the paper and mark the center of each hole.  Take the paper off, then come back and drill them to the right size.
If you have some hole that's different, use a circle template or whatever you need using the mark from the small drill or nail.
danny_galaga:
this was drawn on the wood:
http://moncom.net/mame/
danny_galaga:
godammit, i can never get the picture to go where i want it to...
Pages: << < (3/3)
Go to full version
