Main > Software Forum
StepMania Help
MrBond:
I checked out Dance Dance Revolution 1st Mix just to see what the fuss is about. (Incidentally learned about bit torrent). Stepmania seems pretty cool- but once again, you need the right controls for the correct experience :)
What pads are YOU using? I would definately want 2 for multiplayer.
SirPoonga:
You can find originals all over the place. Frieza, one of the stepmania devs, has some.
http://frieza.stormwerks.net/stepmania/
abrannan:
--- Quote from: MrBond on June 20, 2004, 11:08:09 pm ---I checked out Dance Dance Revolution 1st Mix just to see what the fuss is about. (Incidentally learned about bit torrent). Stepmania seems pretty cool- but once again, you need the right controls for the correct experience :)
I use the DDR Deluxe 2.1 pads from www.levelsix.com with a super dual box adapter from www.electricquarter.com
papaschtroumpf:
is the $6 pad good enough for a "starter" setup? I'm probably not going to get into it but my kids might so I'd like to give it a try so I'd like to find the cheapest setup possible. Looks like you can get a $20 USB adapter, so total cost would be pretty low.
SirPoonga:
you (and your kids) might find that you will want better pads later, but to start out sure. The problem with most soft pads, though, is that they drift around so as you are playing the song the pad moves out form under you. That makes it hard to get the steps.
