Main > Main Forum
Any examples of installing monitor glass/plexi?
patrickl:
I'm gonna use mirror clips (spring loaded clips) on top and set it down on a groove in the wood (or maybe a rail or clips as well). Along the sides of the cab there will be wood strips supporting the wood also.
The clips will be in the area behind the marquee so they will be hidden from view. These clips hold mirrors in place while you clean them, so I assume they will be able to hold the glass on a cab as well.
To take it out, I'll remove the CP, lift the glass (the springs allow the glass to move straight up) out of the groove and then slide it forward and down (the top of the glass will slide along the side strips) and when its slid sufficiently down (so I see the top) I will be able to take it out.
I haven't tried this yet though ::)
