Author Topic: ultimarc trackball and mounting plate  (Read 693 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« on: June 13, 2004, 07:09:44 pm »
do you need to buy the mounting plate for the ultimarc trackball if you buy the trackball?
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
Re:ultimarc trackball and mounting plate
« Reply #1 on: June 13, 2004, 07:13:38 pm »
If you don't have a metal CP, YES.
If you have a metal CP and can cut a whole in it, then no.
Nefesis
« Reply #2 on: June 13, 2004, 07:29:57 pm »
i'll have a wood cp, so i guess i'll have to buy it. :( more things to spend money on.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: June 13, 2004, 07:33:38 pm »
Can't you:
- take off the top part of the trackball case
- route out a hole in a wood CP (to match the top)
- bolt the bottom part of the case to the CP
mahuti
« Reply #4 on: June 13, 2004, 09:16:13 pm »
If you did that you'd really have to spend a lot of time and effort rigging it up correctly, from what I can tell by looking at mine.
I would say it is worth the $14 that it takes to buy the mounting plate... in time alone. Plus, I think the results would turn out MUCH nicer.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: June 13, 2004, 09:33:43 pm »
It would probably be more work than the mounting plate yes. On the looks, I'd say it looks pretty good in the Mini-Multi-Williams hybrid.
I also like to get the ball up a bit higher (so more of it sticks out on top of the CP) than it is inside the case.
Anyway, I still need to try this out once. Perhaps I'll fail miserably, but I'll try it anyway  :P
