Author Topic: Converting this cheap 8-way stick to 4-way?  (Read 730 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« on: June 13, 2004, 03:44:31 pm »
I bought a couple of these dirt-cheap 8-way joysticks on eBay some time ago, thinking that there would be an easy way to change them to 4-way. Their construction is not like any I've seen before. Does anyone have any experience with these?
crashwg
Re:Converting this cheap 8-way stick to 4-way?
« Reply #1 on: June 13, 2004, 10:17:23 pm »
This is what I'd do if I were you.
Take a piece of metal and my dremel and try to construct something like...
       V V V V     This     V V V V
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #2 on: June 13, 2004, 10:34:50 pm »
Don't you just looses those 4 screws and rotate the plastic thing and you will get something like that one pic.
JoyMonkey
    • JoyMonkey.com
« Reply #3 on: June 13, 2004, 10:56:43 pm »
The plastic thing seems to serve no purpose at all; it's exatcly the same no matter which way it's rotated.
JoyMonkey
    • JoyMonkey.com
« Reply #4 on: June 13, 2004, 11:02:48 pm »
This would work, only the stick's throw is so short, it hits the diagonals as easily as it does up/down/left/right. I think maybe I need to find something to act as an actuator thats diameter isn't as large as the one that comes with the stick; thus making the throw longer and making the diagonals harder to hit.
Then maybe I can make a restrictor like you're saying...
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: June 14, 2004, 08:30:36 am »
Hmmmn, I'll throw a couple of things into the mix - those look similar to the www.ultimarc.com J-Stick, which is based on a Sanwa.
I don't know if the J-Stick parts would work on that stick, or if Andy would sell them separately, or if the indivdual price would be more than just buying a J-Stick.  Wouldn't hurt to ask though.
If you don't want them switchable (you want a permanent 4-way joystick), you might look on E-bay for Seimitsu's which are good and cheap (although usually not advertised as that.)
Ed ONeill
  • Last login:April 12, 2012, 10:00:16 am
    • http://home.comcast.net/~coin-opcollector/
« Reply #6 on: June 14, 2004, 10:38:13 am »
Hey I have a few 4/8 way switchable joysticks , you change then by using a smaller diamater plastic piece (actuator?) So I think you are on the right path.
Just my 2 cents
Ed
Always buying Gumball/candy machines and parts email - coin-opcollector@comcast.net
Want list - Diner Pinball, hit the ice cab, tmnt controls and panel
