Author Topic: House of The Dead 2 question  (Read 1102 times)
PinoyArcade
  • Last login:June 09, 2004, 11:21:28 am
« on: June 12, 2004, 11:00:26 am »
can u play HOTD 2 using a PC and a Light gun with an arcade set-up ( you drop coins or tokens to play)?
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
Re:House of The Dead 2 question
« Reply #1 on: June 12, 2004, 12:49:52 pm »
The answer is maybe.  Here are some clarifying questions:
Do you want to play HOTD2 through MAME?  IIRC, it's not available yet.
Do you want to play HOTD2 from a PC version?  I doubt it has a credit mechanic you can tie a cabinet into.  You may also want to check PC light gun compatibility with the game.  The Act-Labs gun are probably your best be for that.
If no one feeds the trolls, we're just going to keep eating your goats.
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #2 on: June 12, 2004, 02:59:17 pm »
You can play HOTD2 as well as other PC games with an ACT LABS gun and a patch that is a available from their website.
PinoyArcade
« Reply #3 on: June 14, 2004, 09:39:54 am »
how about HOTD1...is it emulated already? MAME?
TalkingOctopus
    • My Arcade
« Reply #4 on: June 14, 2004, 01:24:51 pm »
It is not emulated.  There is a PC version.  It works w/ the Act Labs in the same way as HOTD 2.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #5 on: June 14, 2004, 04:15:11 pm »
Actually HOTD1 is emulated by Nebula Model 2.  It's probably a little buggy though.
NoOne=NBA=
« Reply #6 on: June 14, 2004, 04:49:59 pm »
HOTD1 does NOT work with the newer USB Act-Labs guns.
It used some kind of mouse acceleration that the newer guns do not support.
TalkingOctopus
    • My Arcade
« Reply #7 on: June 15, 2004, 01:10:41 am »
Have you tried the patch available on Act Labs site?
* This is a fix that allows the Act Labs USB light guns to work with older games that were previously incompatible with the guns because of the way the games handle mouse input. This Fix also add's support for the 2 Player function on the Act Labs TV USB Light Guns.
I actually don't own the guns, but they list HOTD as playable on their site.  Is the list incorrect?
NoOne=NBA=
« Reply #8 on: June 15, 2004, 01:19:46 am »
They came out with that patch after I got mine apparently.
I'll have to give it a shot.   :o
PinoyArcade
« Reply #9 on: June 25, 2004, 12:31:07 pm »
hello guys, im planning to do my first emulation project using HOTD1 but since Im new in emulation I hope anyone can help me with these questions:
1. What emulator/emulators support HOTD1?
2. What computer parts and its specs do i need?
3. Should I use a mirror in my cab or mount the monitor directly for the light guns?
4. lastly...have anyone here have a light gun mame project in here which I can copy?
thanks in adavance guys
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #10 on: June 25, 2004, 01:57:13 pm »
You can play HOTD2 on a VGA monitor with two players (two lightguns) pretty cheap using a Dreamcast.  As for the coin mech...you can hook that up to the start button (one coin = 1 player start).
