Main > Software Forum
Help with Emulaxian/Fe-3darcade 0.66
)p(:
--- Quote from: MrArcade on August 05, 2002, 10:06:33 am ---
Am I correct in my thinking that I should be able to get another videowall to select video from...which will play full screen? I am having no luck at all with this.
Thanks Again!
Mr Arcade
From your next post it seems that you figured out the first question allready, correct me if I am wrong ;)
something like that...the videowall is just a model like the other models that show up for a gamelist entry, look in your models folder. So yes you can add an entry to a gamelist that points to the video wall and as an emulator uses fevideo.cfg that points to mediaplayer to launch a video fullscreen. You can also have a demo of the complete video playing on the model in realmedia format when you have such a file.
Peter
