Main > Software Forum
Quick Mamewah Question
Pages: << < (2/2)
chrisindfw:
Nope. Im using dos mame. not 32.
I will try again tonight. I will just start with a fresh mamewah and see if I can get it.
--- Quote from: Minwah on June 07, 2004, 10:31:24 am ---
--- Quote from: chrisindfw on June 07, 2004, 08:38:42 am ---Do I need to create a listinfo file or something. What about the dat file?
No you don't need to do anything for MAME - just make sure your MAME 'Emulator Executable' and your 'ROM Path' are correct.
You're not using MAME32 are you?
Minwah:
--- Quote from: chrisindfw on June 07, 2004, 12:30:15 pm ---Nope. Im using dos mame. not 32.
Try Windows Commandline MAME...DOS MAME should work too, but I haven't tested it for a loooong time ;)
chrisindfw:
I'm sorry.. I didnt know there was  "DOS" mame.. I am using the command line mame.
--- Quote from: Minwah on June 07, 2004, 02:51:21 pm ---
Minwah:
--- Quote from: chrisindfw on June 07, 2004, 03:14:24 pm ---I'm sorry.. I didnt know there was  "DOS" mame.. I am using the command line mame.
In that case you probably have the Windows one...check if you use a mame.ini file (Win) or mame.cfg (DOS).
Pages: << < (2/2)
Go to full version
