Author Topic: buy a countersink/screwdriver (if you don't already have one)  (Read 1157 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
I worked on my cabinet today and it was extremely helpful.  It saves a ton of time.
I imagine that most regulars already have one, but just thought I would suggest it to the ones who don't and for the newbies.
(this site has it pretty cheap too)
MameMe
  • Last login:June 08, 2005, 06:45:25 am
Re:buy a countersink/screwdriver (if you don't already have one)
« Reply #1 on: June 06, 2004, 07:57:52 am »
Instead of buying one you could always do what I did...
Assuming I would be wood-filling the counter-sink hole with wood filler, I simply used a drill and a typical "star screw bit" and drilled my own counter-sink.  All I did was hold the drill against the wood for a couple seconds and voila!
After wood filling it everything looks fine!  And its free.. ;D
« Last Edit: June 06, 2004, 07:58:25 am by MameMe »
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #2 on: June 06, 2004, 10:39:27 am »
big problem with those countersink bits is the drill bit is only like 1/2" long, making it USELESS for pre-drilling.
BYOAC users get 5% off with coupon code byoac5
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #3 on: June 07, 2004, 12:34:52 am »
Contrary to this opinion, the drill bit should be at least an inch long, probably more like an inch and a half long.  Take the end with the little allen key nub and loosen the set screw that holds the drill bit in the countersink portion.  Pull the drill bit out, making sure not to pull it out further than the set screw opening.  Tighten the setscrew.  Fire away.  You may not be able to flip it around back into the holding mechanism (if yours is set up like that, that is), but that's the only downside to doing that.
Bumblebounces
  • Last login:January 26, 2016, 07:57:28 pm
  • I ever tell ya 'bout Bumbles? Bumbles...BOUNCE!
    • Starbase 74
« Reply #4 on: June 07, 2004, 12:56:48 am »
I have used one of these for years.  I would not build a thing without it.  In fact, the one I have is a little on the worn side.  The hex piece that fits inside the body has started to "round off" a little from continual use.  This makes it stick in the holder sometimes.  I STILL would not be without this thing when building ANYTHING.
BTW...  The drill bit is adjustable and there is ample room inside the body for the full extension of the bit (on the one I have at least -- it's a Makita similar to the posted pic but I bought mine years ago so I don't have the cool case)
Bumble
Wade
  • Last login:November 29, 2023, 08:30:51 pm
  • 80's Child
    • Wade's Gameroom
« Reply #5 on: June 07, 2004, 10:30:24 am »
When building a cab, why not put all the screws on the inside so there is no filling or countersinking necessary?
Wade
mmmPeanutButter
« Reply #6 on: June 07, 2004, 12:19:55 pm »
Wade
I agree... screw from the inside (where you can).  But even when you screw from the inside, if you use a countersink bit with a countersink screw, you can have a clean look on the inside because everything will be flush (even if you decide not to fill them).  Also helpful if you have clearance problems where a screw head protruding would be a problem.
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #7 on: June 07, 2004, 10:51:45 pm »
Yeah, I'm gonna have to try one of those things.  I'm constantly screwing things together with my cordless screwdriver.
Wade
