Main > Software Forum
mamewah and batch files
Minwah:
--- Quote from: wassabi on June 06, 2004, 04:05:01 pm ---Please Minwah, I am sorry I didn't explain this better. Pressing start for the first item on the list is what I ment.
I would like to know how I can do it.
Pressing start is just hit '1'...
Are you having trouble actually generating the list with your app. in it? If so, there is a section about how to do it in the MAMEWAH readme ;)
wassabi:
Guess we got a RTFM situation.
New problem though, can't get the ap to start after starting it in Mamewah. I'll press 1 then the system will hang with the message starting ap, till I press crt+alt+del.
Here's a snipet from the cfg and I'm only including the lines I changed from default.
--- Code: ---ROM Path = C:\LINKS
ROM Extension = LNK
List Generation Method = 0
;EXECUTION SETTINGS
Emulator Executable = PC
Send ROM Path = True
Send ROM Extension = True
Show DOS Box = 0
--- End code ---
Minwah:
--- Quote from: wassabi on June 07, 2004, 08:34:30 am ---New problem though, can't get the ap to start after starting it in Mamewah. I'll press 1 then the system will hang with the message starting ap, till I press crt+alt+del.
Set Show DOS Box to '1' - some PC apps (& emus) require this.
wassabi:
That did the trick thanks for the help!
Minwah:
--- Quote from: wassabi on June 07, 2004, 11:58:26 am ---That did the trick thanks for the help!
Great, got there in the end! :)
