Main > Software Forum
PC versions of Mortal Kombat 1, 2, & 3
Pages: << < (3/3)
Malachai:
--- Quote from: Howard_Casto on June 02, 2004, 09:15:02 pm ---Playstation... bah!  N64 is the best version.
The best version of mk4 is mkgold, which is on the dreamcast.
I second that! :)
seibu:
Have you tried MK1, 2 and 3 through some older versions of MAME? IIRC they used to run a lot faster - apparently a lot of speed hacks were taken out of the drivers recently.
NoBonus:
any ideas on the best version of mame for MK?
Howard_Casto:
--- Quote from: seibu on June 03, 2004, 06:55:01 am ---Have you tried MK1, 2 and 3 through some older versions of MAME? IIRC they used to run a lot faster - apparently a lot of speed hacks were taken out of the drivers recently.
Yeah but they were faster because of inaccurate drivers.  The timing was a little off and the sound fx were bad.  Even console ports would give a better feel than that.  Imo if you can't run it properly then don't bother.
Pages: << < (3/3)
Go to full version
