Author Topic: Dimentions for 33" Shocase Cabinet  (Read 8116 times)
lostboy4480
  • Last login:February 21, 2024, 06:54:46 pm
« on: May 30, 2004, 01:47:49 pm »
Does anyone have any dimentions for a showcase cabinet like this HanHo one ?
I am trying to decide if I will build a Simpsons style cab or one like this (If I can find dims for this style)
Thank you
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
Re:Dimentions for 33" Shocase Cabinet
« Reply #1 on: May 30, 2004, 07:54:14 pm »
That looks almost exactly like my Dynamo Showcase cabinet. What dimensions do you need?
www.wolfelectronics.ca
Cap Kits for Canadians!
Electron
  • Last login:December 13, 2004, 05:17:54 pm
« Reply #2 on: May 30, 2004, 08:10:24 pm »
Main Base:
42" high to the bottom of the monitor.
33" wide from left to right
9" high from the floor to the top of the front of the base
12" deep for the torso of the base
Control Panel base:
25" deep front to back
17" wide at the front of the base
30" high up to the bottom of the control panel
33" wide at the back of the base
18" wide at the back of the base
Monitor cabinet:
48" wide
29" Tall
8" to 12" width curved front
Control Panel:
5" tall
48" wide
16" deep
130 degrees angle at top of panel
90 degrees angle at sides of panel
150 degrees angle at bottom of panel
Thanks to Greg for these. He sent them to me a while back.
lostboy4480
« Reply #3 on: May 31, 2004, 12:51:21 pm »
Thank you, I will see if I can come up with a plan from this information :)
Will post finished plan here incase anyone else is interested
Cabinets
NBA Jam
Golden Tee 2005
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #4 on: June 01, 2004, 12:22:31 pm »
I am interested.
Felix T Cat
  • Last login:September 08, 2020, 08:48:29 am
« Reply #5 on: June 01, 2004, 01:48:45 pm »
I would love plans for this as well (even though I still haven't gotten off my a** and built a regular cab yet).
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #6 on: August 05, 2004, 07:08:17 pm »
Main Base:
Control Panel base:
Monitor cabinet:
48" wide
29" Tall
Control Panel:
5" tall
48" wide
16" deep
not to ask a stupid question...but if somone has time..can somone write measurements on the picture listed above?
i believe not all the measurements are listed for this.
some entrys don't tell where it belongs...i can guess but it still wouldn't make sense...
the one with most problem is the control panel base.
monitor cabinet, the width is missing... i would think it's 6 inchs...
or it it 8 inchs in the front, since it's curved, the front middle would be about 12 inchs.???
i'm not concerned w/ the cp (different desgin and plans)
thank you
