Main > Software Forum
MameWah changes my resolution?.?...
Pages: << < (2/2)
AGGIEZ:
--- Quote from: Minwah on May 26, 2004, 07:41:09 pm ---
--- Quote from: simplygriff on May 26, 2004, 04:25:04 pm ---Now that you mention it it is usually when I do something stupid like hit the windows key or shift too many times and turn on sticky keys.  I think things will be fine when I start using my joystick all the time.
-G
How do you turn off Stickykeys??
Some apps can steal focus from MAMEWAH too - check it isn't that.
Turn the annoyance that is Stickykeys off too - Shift is a standard MAME button so could still give you jip with sticks/buttons...
And MAMEWAH will work with any resolution, as long as your video card can successfully change to that res...
Minwah:
--- Quote from: AGGIEZ on May 26, 2004, 08:24:45 pm ---How do you turn off Stickykeys??
Control Panel > Accessiblilty Options
Untick 'Use StickyKeys', click on Settings and untick 'Use shortcut'.
simplygriff:
I haven't had any more problems with it since I turned off sticky keys and am more careful about hitting that windows key.
And I got it running at 1600x1200 with no problems last night.  Even dabbled with the layout designer.  Pretty neat stuff.
-G
Pages: << < (2/2)
Go to full version
