Author Topic: coin doors uk?????  (Read 1337 times)
shaneMacgowan
  • Newbie
  • Last login:May 21, 2004, 08:47:17 am
coin doors uk?????
« on: May 21, 2004, 08:56:51 am »
Hi everyone!
I think i understand that i need a coin door and a coin mech to go in the door for my arcade machine. Its just the switch that the correct coin entered triggers that needs to be connected to the ipac board???
Thats fairly straight forward - but are there any tutorial sites out there for adding a coin door with the ipac card?
Also, where the hell can i get the coin door and mechanism in the uk?
Thanks in advance!  ;)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
Re:coin doors uk?????
« Reply #2 on: May 21, 2004, 01:30:19 pm »
Since you are in the UK, I will step in as most people here are in the US:  In the UK it is VERY common for machines to have coin mechs which can accept multiple coin types (10p, 20p, 50p,
DaveJ-UK
  • Last login:September 16, 2021, 06:26:07 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #3 on: May 21, 2004, 04:05:38 pm »
I have a 10p/20p/50p/
barry
  • Newbie
  • Last login:December 10, 2005, 03:40:48 am
Re: coin doors uk?????
« Reply #4 on: December 02, 2005, 08:44:54 am »
Hey guys. I have a Coin Controls Credit Control unit. I have found the dip switch settings so i'm OK with that but I can't seem to get it work with my JPAC.
Should just connecting the JAMMA edge connector to the JPAC be enough or do I need to reroute some wires somewhere?
The coin mech lights up and is powered by a PSU in the cab.
I don't want to damage the JPAC, is there any danger in connecting it?
All advice gratefully received.
Hippo
  • Last login:February 28, 2007, 10:07:46 am
  • Building a Cab In Blighty!
« Reply #5 on: December 02, 2005, 11:16:33 am »
If you wanted to do it without mechs you could do what I did here http://www.aphdesigns.co.uk/arcade/
