Main > Main Forum
If you had it to do over
Pages: << < (6/6)
Bumblebounces:
--- Quote from: danny_galaga on May 31, 2004, 10:52:45 am ---
--- Quote from: Bumblebounces on May 29, 2004, 04:31:31 pm ---3.  I would have planned to use a WG 27 inch arcade monitor instead of trying to make a rotating 19 inch.
is yours a cocktail too? my bubbles been burst once already! if it is a cocktail do you have any pics or a page i can link to?
No.  It was a full size cab and I ended up abandoning the rotation altogether as it was just going to be too hard to make it happen.  I actually had a turning drum built but the damned monitor I had was so heavy that it was very difficult to turn.  (I didn't take any good pics of it while I was building it, but I did catch it in another pic...  See the background of the attached).  I designed it with a motor drive and limit switches in mind but after I saw how hard it was to turn, I decided that the motor to push this thing was going to cost too much.  I took comfort in the fact that the cab design I had gone with to accomodate the turning drum would also accomodate the WG D9200.  I just didn't have the funds for the 9200 at the time to make it happen.  Still waiting.  Sometime early next year, I hope.
Bumble
EDIT:  Oops, the attachment didn't take the first time.
RayB:
" decided that the motor to push this thing was going to cost too much. "
You probably just needed to gear it so the motor would be turning fast, but the monitor slow.....
danny_galaga:
for more info on rotating monitors:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=19247
and in this thread the guy has his in an upright mounted vertically (with mirror):
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=19105;start=msg159529#msg159529
there is a lot less load this way
Bumblebounces:
--- Quote from: RayB on May 31, 2004, 02:15:33 pm ---You probably just needed to gear it so the motor would be turning fast, but the monitor slow.....
I could have made it happen but that meant stopping work to go back to design phase.  I found many motors that could have worked but they all cost money I didn't have at the time of need.  If they had been $15-$20, I would have gone for it but they were $50-$100 and I was already so over budget (still am, I don't have my Tornado spinner yet, either).  I made a command decision to forge ahead and planned to get a bigger monitor at a later time.  Although the idea was a great one, I just decided that a rotating monitor was unnecessary.  I have been using my cab for a few months now and though I wish the monitor was either bigger or oriented correctly for each game, I am very happy with the results.
Bumble
RayB:
I understand the dilemma. I too was thinking of ideally making a rotatable (not motor driven though). In the end I think what I'll have is 2 cabinets. An upright for horizontal games, and a cocktail for vertical games. Why not?
Pages: << < (6/6)
Go to full version
