Author Topic: 720 + P360 = Close Enough?  (Read 1463 times)
Knoxximus
  • Last login:December 19, 2011, 12:22:58 am
  • Young Frozen
    • Beat-TECH Productions
« on: May 20, 2004, 02:43:53 am »
I was just wondering that since the P360 is an optical joystick with no clicking or "corners" to hit, does using these make for a decent game of 720?
Dumb questions deserve dumb answers.
Jakobud
  • Last login:May 05, 2024, 10:53:37 am
Re:720 + P360 = Close Enough?
« Reply #1 on: May 20, 2004, 03:10:58 am »
Well 720 actually uses a spinner, not a joystick.  I'm not sure if you can setup 720 to play with a joystick in Mame.  I am probably wrong, but I know by default it uses the spinner, like in the arcade.
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« Reply #2 on: May 20, 2004, 04:06:39 am »
I have the Happs Optical sticks and have played 720 with them..not too bad, better than a regular joy, but nothing compares to the real thing!
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
« Reply #3 on: May 20, 2004, 06:58:23 am »
I wouldn't have thought the P360's would be much/any better than most other 8-way digital sticks.
I think you have to use MAME Analog+ to use an 8-way (or analog, or orig. arcade stick) stick well with 720deg in MAME.  I have never done it so please correct me if I'm wrong...
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: May 20, 2004, 11:40:59 am »
Yeah, p360's would probably work the same as an 8way.  You can use Mame Analog+ so that when you push in a direction the skater will jump into that direction.  The biggest problem is that the game itself uses 16 different directions, so with an 8way  joystick, the skater's direction will skip over directions making it substantially more difficult to control.
http://jstookey.com/arcade/720/720-instructions.php
It got me thinking, though - if you could throw a ball top onto a 49way and use the new 49way->PC analog joystick interface, that might be a pretty good alternative!
« Last Edit: September 27, 2006, 12:25:50 am by jerryjanis »
Knoxximus
  • Young Frozen
« Reply #5 on: May 20, 2004, 12:01:00 pm »
So it works good with a spinner then?
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #6 on: May 20, 2004, 12:17:12 pm »
I can't stand playing with a spinner.  The 720 joystick has a second encoder wheel attached which keeps the joystick calibrated so that the direction you point the joystick will be the direction the skater will point in.  You know what direction you are going blindfolded.  With a spinner, there is no such control which makes it a lot more difficult to come out of a wild aerial spin without crashing.
Lilwolf
« Reply #7 on: May 20, 2004, 02:14:04 pm »
I think the closest will be (other then original controller) will probably be using an analog joystick and hack a ball top stick.  Then use analog+ or noname mame.
But most others do stink.
you have to be able to stop quickly in a given direction.  Spinners don't allow this.
Knoxximus
  • Young Frozen
« Reply #8 on: May 20, 2004, 02:52:48 pm »
Where can I get information this type pf control?
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #9 on: May 20, 2004, 03:05:50 pm »
I don't have any first-hand experience.  Here's the thing, though:  a PC analog joystick is functionally a pretty decent alternative to the 720 joystick, except for the problem that they don't have an arcadey feel at all.  The other problem is that they have a centered position (unlike the 720 joystick) which means that it might take some discipline to stay on joystick's outside circumference.  The 49way should have a much better arcadey feel to it.  Since 720 demands 16 directions, and the 49way can supports that and more, I think it might work pretty well.
Here's a link to a thread which discusses daveb's 49way joystick interface:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=17230;start=msg136541#msg136541
Of course, if you're feeling really hard-core about 720, then you may need to look into interfacing an actual 720 joystick like I did.  There's details on how to do that on my site:
« Reply #10 on: May 21, 2004, 05:24:59 am »
I hear what you're saying about PC analog sticks, but is there any reason why a 49-way stick would work better than a 'normal' analog arcade stick?
Edit: Are 49-ways just analog in the directions?  What I mean is do they have the analog range than normal analog stick's do?  (I should know the answer but I've never used a 49-way before)...
« Last Edit: May 21, 2004, 05:29:05 am by Minwah »
ericball
  • Last login:January 30, 2024, 03:07:18 pm
« Reply #11 on: May 21, 2004, 11:07:31 am »
49ways have a 7x7 positioning grid, versus 8ways which have a 3x3 positioning grid.  Analog grid is dependent on the resolution of the analog to digital converter (i.e. an 8-bit ADC would give a 256x256 grid).  49ways are halfway between an 8way and an analog stick.  They provide some additional resolution while still being digital and therefore accurate & consistent.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25%
2004 Tempest cabinet & CP > 75%
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #12 on: May 21, 2004, 12:34:41 pm »
What's a 'normal' analog arcade stick?  Most of them are flight sticks, aren't they?  For 720 there wouldn't be any difference functionally, it's just that the feel of a flight stick would be terrible for 720.  Happs sells their "analog joystick with ultimate handle", though, so maybe that would be good, too.
« Reply #13 on: May 21, 2004, 01:40:48 pm »
Thanks, that explains perfectly :)
jerryj: I suppose most are flight sticks, but I was just thinking of the working principal rather than the handle...
Lilwolf
« Reply #14 on: May 21, 2004, 02:24:38 pm »
btw, I have a 49 way + daves board
but it has the spider on the bottom.  So it won't work well.
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #15 on: May 21, 2004, 02:27:50 pm »
What do you mean it has the spider on the bottom?
NoOne=NBA=
« Reply #16 on: May 21, 2004, 02:43:40 pm »
It's a big rubber X, that they used on the Sinistar sticks to help center them quicker, and provide resistance to movement.
It's basically like having rubber bands connected to the bottom of the stick, and then stretched to the outsides of the joystick base.
Knoxximus
  • Young Frozen
« Reply #17 on: May 23, 2004, 02:25:05 pm »
Kinda like a shock mount on a condenser mic.
