Main > Software Forum
Mamewah and WinXP's remote desktop?
screaming:
--- Quote from: drunkatuw on May 21, 2004, 03:08:03 pm ---I think the problem (atleast with vnc) is that once you enter a game, the resolution switches and vnc disconnects. If you changed you mame.ini file so that mame runs in the same resolution as mamewah then vnc should not disconnect.
This is usually what happens.. I notice that with Dragon King it does it more so because it forced the resolution change, even if the screen is set at the resolution already.
UltraVNC seems to handle the resolution changes the best, and only drops my connection once in a while.
-S
