Main > Software Forum
VP-Launch.exe ---> I need help !
Pages: << < (3/3)
Ekstreme:
Sorry to come across dumb, what what is vplcfgs folders? I definately don't have that
Howard_Casto:
It's inluded in the vplaunch4.0 zip file.  You should have it.  Bet we just found your problem.  :)
Ekstreme:
WOOHOO!! Thanks a bunch!
My mistake, I was just draging the file out of winzip. Didn't even see that the default.ini had a path to it.
Now, any tips as to why the scoreboard will never stay on top :D
MisterB:
I'm having the same path issue, but I keep my tables in a separate directory from the VP install directory.  Howard, does it need to be in VP's install directory, or the directory that I keep the tables in?
(or do I have to move my tables into VP's tables directory  :-[)
Howard_Casto:
It needs to be with the tables.
But for the record visual pinball tables (non pinmame ones) won't operate properly unless they are in the tables dir inside the visual pinball dir.  The sound fx and music files are stored in a common directory within vp and older tables don't dynamically search.
Pages: << < (3/3)
Go to full version
