Main > Main Forum
Virtua Fighter cab questions
pakchooi:
I just picked up the cab, apparently the board is ok, but the powersupply is
gone. Looks like a restoration is feasable after all:D
Any good links for 2nd hand psu's?
SkateDetroit:
Did you check the fuses on the power supply?
pakchooi:
When I say *gone* I mean not there at all.
Removed.
ChadTower:
FYI:
I talked to Andy @ Ultimarc to see if they had plans for a medium res ArcadeVGA driver. He said they didn't, but he did give me his honest opnion (seeing as how I was no longer looking to purchase his card, I see ho reason he wasn't honest) on the Blade card solution. According to him it's not all that great a solution, that it works, but it's probably the least of the solutions in terms of end results.
So for those of us with Medium res monitors, it looks like AdvanceMAME is it.
Superdude:
You will run into one problem running DOS though. You will hit the PEAK point in DOS. (MEANING you can have a PC that is VERY FAST but won't help in DOS) If you need my .CFG files for ADVMAME and ADVMENU let me know soon. A guy just bought the machine from me and is paying me little by little for it. I can snag it off for ya, and since it is the same machine monitor it should work perfectly.
