Main > Main Forum
PS2 Logitech wheel on PC?
Pages: << < (2/2)
mcdo15:
--- Quote from: simplygriff on June 01, 2004, 10:39:07 am ---
--- Quote from: mcdo15 on June 01, 2004, 10:29:35 am ---installed on it's own (usb)
Sounds even better!  I may break that thing out this week and check it out.
Do you have to use a PS2 adapter or does it just load up totally through the USB port?
just usb
wboy:
--- Quote from: simplygriff on June 01, 2004, 10:16:44 am ---That's actually the one I have.  I guess Maybe I described it wrong.  It's been in a closet since I moved.  That's awesome that it works though.
I'll go try to find that driver.  Thanks for the info!
-G
Ummm, no... I just assumed you had the latter one, as the original GT force wheels are quite rare these days.  Whats even worse, is that a few car games released of late only work with the newer wheel I mention... not the original GT Force....  ::)
simplygriff:
Yeah... I tried to use it with Tokyo Extreme Racer Zero and it didn't work.  After that I never tried it with any newer games.  The only one I picked up was NFS: Underground.  That was pretty cool with the pad though.
Least it's awesome with GT3.  That's what truly made that game 8)
wboy:
Well I went out and bought this sucker! ;D
http://nascar.about.com/library/weekly/aaprlogitechmomoforce.htm
Works perfectly with GT3, GT3 Concept.... though same game compatibility probs as the GT Force in latter games.
Only problem is this wheel is now effectively redundant, as the new GT wheel for GT4 supports a 900 degree turning circle, versus the 270 degrees that the GT force/Momo has.
This supposedly makes rally driving a treat in GT4.
Time to move forward I guess... )
simplygriff:
Yeah I like that the new wheel has the gear shift for GT4.  Too bad I already have 1 $100 Wheel :P
-G
Pages: << < (2/2)
Go to full version
