Main > Software Forum
MAME32 No Name MAME32 problems
Pages: << < (2/2)
CGRemakes:
--- Quote from: TheGatesofBill on May 18, 2004, 07:43:09 pm ---I really don't know. Have you tried starting with just No Name and the ROMs? Delete anything else in the folder.
I haven't, though I will.  The fact that it does it in both MAME32 and No Name 32 (and previous versions as well) leads me to believe there is some sort of driver issue or something that is conflicting that prevents it from loading.  I may just use the command line versions and call it good.  Thanks for the help, I will post if I figure out the problem, or if your suggestion does in fact fix it.
TheGatesofBill:
You'll find that is my solution for many things, but it tends to work alot. ::)
CGRemakes:
--- Quote from: TheGatesofBill on May 18, 2004, 09:18:19 pm ---You'll find that is my solution for many things, but it tends to work alot. ::)
Sorry, this didn't fix the problem.  Oh well, I will get by with the command line versions just fine.  Thanks for the help.  :)
Pages: << < (2/2)
Go to full version
