Main > Software Forum
can you change the volume in specific games?
Pages: << < (2/2)
hulkster:
um....wow....why didnt i think of that before.  only thing is, i have to change the volume for every single game just because like 3 or 4 games have low volume :-\.  could i adjust the volume in mame32 for all games, and then hopefully when i pull up the tilde menu it will be set as such?  im at work right now or id test it.
AlanS17:
I *believe* the IPAC/JPAC shortcut for volume control is hold start and press up on the joystick. You can then adjust it with the joystick and press start and up again to close volume control.
hulkster:
hmmm....well i would rather have it set initially though ::)  i dont know, i may try the set the volume low for all games except for the games that have low volume, and then turn the speakers up really loud.  but then games like tiger woods and golden tee that i have for my pc, will be super loud! >:(
AlanS17:
Well is volume a global setting in MAME or is it specific for every game like key mapping? Regardless, it should save your settings when you exit so the next time it'll keep your volume and you should only have to do it once.
bigmoe:
--- Quote from: AlanS17 on May 18, 2004, 04:26:52 pm ---Well is volume a global setting in MAME or is it specific for every game like key mapping? Regardless, it should save your settings when you exit so the next time it'll keep your volume and you should only have to do it once.
It doesn't save settings for the tilde approach :(.  Don't know about any other strategy...
Pages: << < (2/2)
Go to full version
