Main > Software Forum
MAMEWAH v0.97 Released!
Scoobie:
Looking forward to it! ;D
Dave Butler:
I'm Not :'(
Minwah:
--- Quote from: Dave Butler on July 21, 2004, 05:02:37 pm ---I'm Not :'(
Heh, if it's any consolation it is just about doing head in atm! :D
Seriously tho, I don't think *most* of it will be too difficult for you. My new controls/input system consists of a file system very similar to MAME's ctrlr ini files - I guess if you wanted to add detailed support for that into MW Setup, then that would be pretty challenging, but to be honest I don't think you'll need to, as most people will probably only need to edit 1 file once (the system is a little overkill really, but well prepared).
The ctrlr files I mention, along with my new config system will be backward compatible with new versions of MW...and the config files even auto-update themselves, so I suppose that will remove the need for MW Setup to update the CFG files ;)
I'll get in touch a little nearer to when I'm ready (I'll try and give you some more warning this time)...atm MW is a bit of a mess, with things not working here and there, so I have a fair bit to go yet.
pointdablame:
Take your time to get it right, but man I can't wait!!!
* pointdablame bounces with anticipation
FoX:
Does this upcoming version contain mouse/trackball support?
