Main > Software Forum
What is NoNameMame?
Tiger-Heli:
--- Quote from: simplygriff on May 13, 2004, 01:32:05 pm ---As another newbie here...
Would this replace commandline mame where as I would need to have a Frontend to run easily or is it a standalone like MAME32?
Well, I use and recommend the commandline version which requires a frontend, but there are NoNameMAME32 versions which replace MAME32 and don't need a frontend.
simplygriff:
Ok.
I'm sure this is answered elsewhere but is there USB joystick support in NoNameMame? I know I can use a USB stick in Mame32 and that I can use joy to key for Commandline Mame under MameWah and but would NoNameMame save me the trouble of using joy to key?
-G
Tiger-Heli:
--- Quote from: simplygriff on May 13, 2004, 02:42:52 pm ---Ok.
-G
Not sure - AFAIK, commandlineMAME, NoNameMAME (all versions), and MAME32 all support USB joysticks, so I assume you are using JoytoKey for MameWah, but I'm not sure beyond that . . .
simplygriff:
Fair enough. Thanks for the info! ;D
BTW,
What's your software set-up Tiger-Heli? Are you using a FE?
-G
