Author Topic: What is the Happ trackball connector  (Read 5159 times)
andrewonawall
  • Last login:March 10, 2007, 09:29:41 am
  • Beware of the fighting llamas!
« on: May 09, 2004, 06:53:32 am »
I haven't purchased my trackball yet, but I will be getting one made by Happ.  I order everything that I need from one vender in one order to save on the shipping cost, and Happ is the last on my list.
Right now, I am placing an order with therealbobroberts and wanted to pick up a connector for the trackball.  I want to have the wiring set up so that I can just unplug the trackball from the wiring harness if it needs to be serviced or replaced.  What specific kind and size connector do I need for this??? Happ lists 'standard AMOA harness included' on their sight.  Is this the connector that is used???
Build it once and build it right! Revise only as your dreams grow.
drunkatuw
  • Last login:April 24, 2024, 09:17:42 am
    • Drunk at UW.com
Re:What is the Happ trackball connector
« Reply #1 on: May 10, 2004, 04:48:02 pm »
I think the answer depends on how you're connecting your trackball to your computer.
First I used a mini-pac which does not need any connectors...just plug the mini-pac into the trackball and you're set.
Then I switched to OSCAR's mouse hack and purchased a trackball harness for I think $9 from OSCAR.  It works great!
andrewonawall
« Reply #2 on: May 10, 2004, 10:08:36 pm »
I am going to use an opti-PAC from Ultimarc.  I could just chop of the Happ connector and wire it straight to the opti-PAC, but then I can't easily pull out the track-ball without disturbing the wiring harness.  I think that it would be easier to buy the coresponding connector to the one that comes with the Happ track-ball for a couple of bucks.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: May 10, 2004, 11:45:04 pm »
Typically, the Happ trackball wire harness has two 4-position .156" molex receptacles (although MTA receptacles would work too) - one for each optic board (X and Y) on the trackball.  Those two join together to a single a 6-position .093" molex plug (the two +5V and GND wires come to a single pin).
So if you want to make an interface to an Opti-PAC, use this style connector on the trackball, and then make a separate one which has a 6-position .093" molex receptacle, and then have those wires go to the Opti-PAC.  That way, to disconnect the whole thing, you just unplug it where the 6-position .093" molex plug and receptacle meet.
andrewonawall
« Reply #4 on: May 11, 2004, 04:18:48 am »
Thanks, that is exactly what I want to do.  ;D
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #5 on: May 11, 2004, 12:24:04 pm »
I don't know if it's the same connector (I suspect it is) but I got the 6-position Molex that fits my Betson/Imperial TB at Radio Shack. :)
Ken Layton
  • Guru
  • Technician
« Reply #6 on: May 26, 2013, 02:47:41 am »
Here's the Radio Shack numbers for the 6 pin Molex trackball connectors:
274-226 Male .093" Molex 6 pin housing and male terminals $2.99
274-236 Female .093" Molex 6 pin housing and female terminals $2.99
  • Last login:Today at 12:28:31 pm
Re: What is the Happ trackball connector
« Reply #7 on: May 26, 2013, 05:05:20 am »
Congrats, Ken.
I think you're the winner in the necro-bump competition -- 9 years, 2 weeks.   :o
Ken Layton
  • Guru
  • Technician
« Reply #8 on: May 26, 2013, 11:35:17 am »
Congrats, Ken.
The amazing thing is that after all these years, Radio Shack still sells these connectors!
Since this thread started, Happ has jacked the price of trackball assemblies way up:
http://na.suzohapp.com/amusement_products/trackballs/56-5500-12T
