Main > Software Forum
MAMEWAH most wanted...
Pages: << < (16/24) > >>
jcrouse:
MinWAH....I run my skin in vertical mode because it's in a cocktail cabinet. My snaps didn't display properly so you sent me a "fixed" exe file. Will those fixes be incorporated in the new version?
Thanks,
John
MisterB:
If you could implement a default IPAC config file file, that would be great.  I am always running into the problem of programming a game or emulator with a set of buttons that aren't compatible with my MAMEWAH settings, so when I quit the game, I'm not able to navigate through MAMEWAH again.  If you could launch an emulator-specific .ipc file when starting a game, and the option to laun ch a MAMEWAH-spevific one when you quit the game, that would be great.
Minwah:
--- Quote from: jcrouse on May 14, 2004, 07:08:19 am ---MinWAH....I run my skin in vertical mode because it's in a cocktail cabinet. My snaps didn't display properly so you sent me a "fixed" exe file. Will those fixes be incorporated in the new version?
Yes, that was the first update to be completed actually :)
Minwah:
--- Quote from: MisterB on May 14, 2004, 07:22:48 am ---If you could implement a default IPAC config file file, that would be great.  I am always running into the problem of programming a game or emulator with a set of buttons that aren't compatible with my MAMEWAH settings, so when I quit the game, I'm not able to navigate through MAMEWAH again.  If you could launch an emulator-specific .ipc file when starting a game, and the option to laun ch a MAMEWAH-spevific one when you quit the game, that would be great.
That's done too :)  I haven't tested this as such, since I'm using my IPAC in PS/2 mode, and it seems to not want to program atm :(
Please let me know if it doesn't work properly or if I've forgot to do something...
arcadecab:
Minwah,
It was mentioned before about the ability to cut off the excess stuff at the end of console rom names:  for instance just seeing Super Mario Bros.  in the gamelist instead of Super Mario Bros. (USA) [o1], etc.   You mentioned it may not be that hard to do--this would be a GREAT addition I think as I truly hate looking at the extra stuff in trying to make my setup look as "professional" and "non-pc" as possible.  Any chance in the next release?
Thanks.
Go to full version
