Main > Software Forum
Anybody ever had a mame machine that also worked with the KI Emulators?
Pages: << < (2/3) > >>
Minwah:
Howard_C:  Am I correct in thinking that I read somewhere that your new fe/utilities will allow not only launching non-commandline-driven-emulators, but also key-mapping to eg quit the emulators?
I'm really beginning to look forward to this :)
Howard_Casto:
It'll do both. :)  It has about a 96% success rate.  I say that because once in a blue moon you find an emulator that won't work 100% with it.  (For example, due to a coding glitch in zinc, you can only force exit with the esc key in xp.)  Other than that it pretty much solves any launching problem.
After the release I will need other fe developers input.  I have a listgenerator that I want to make universal between the other fe's for example.  It runs off of rom verifying dat files, so it seems to be a very robust solution.
Jakobud:
I can't get the U64 emu(s) to work on my cabinet unfortunately.  They work pretty well on my regular Win2000 workstation but when I try to run them on my cabinet (which is also running Win2000) it is very unstable and the speed is throttled way too high, which I don't know how to change (if you can) in U64Emu....anyone have a thought here?
Jakobud
Howard_Casto:
The emulation is just bad... unfortunately there's not much you can do for it.
jaquer:
I don't know where I read it, but it worked for me. If you check the lock vsync box then the game speed becomes playable, even though the into movies still fly by.
Hope that helps.
Go to full version
