Main > Software Forum
Dragon King and Z26 Bad file name or number
Shieldwolf:
try this on:
bad command line switch seen
or file not found ... (atari).a26
which is odd cons
dk dir
[Dirs]
***Enter all your rom paths... Just like you do in a mame.ini
roms=E:\mame\roms;E:\z26\roms;E:\zinc\roms
***Put These in as a base folder. I.E. If your snaps are in "e:\mame\snap\"
***then the entry should be: "e:\mame\"
Primary Artwork Dir=e:\mame\
Additional AW Dirs=e:\z26\;e:\snes\
***The alternate elements allow you to have two more artwork elements besides the usual.
***Simply put the name of the sub folder (like "\controls\").
***Note: Skins must have an alt-element slot defined for this to work.
AltElement1=\cpanels\
AltElement2=\misc\
[startvd]
[path]
caption=Mame
useclones=0
searchstrings:5=MAME
filters:6=*mature*;9=*Working No*;6=BIOS
[/path]
[path]
caption=z26
useclones=0
searchstrings:5=Z26
filters:
[/path]
[path]
caption=Zinc
useclones=0
searchstrings:5=Zinc
filters:
[/path]
[/startvd]
z26.cfg
[Config]
extension=.a26
path=E:\z26\
exe=z26.exe
send rom path=1
send exit keys=0
command line options=
emulator is on a cd=0
roms are on a cd=0
Emulator Volume Label=
Roms Volume Label=
Shieldwolf:
did anyone figure out what I'm doing wrong?
Teknique:
Sheild,
1. Be sure when you created your dat you called it z26- look inside and be sure the first line says z26 too.
2. If you can run the emu. outside DK, and can not run it inside DK then you need to use the command line wrapper and point the z26 cfg to the wrapper.
*edit*
When you use Iziramn's Dat maker you can call the dat whatever you want to. Just be sure you called it what your cfg. is called and what your calling it in your 5= xxx in your dirs.ini
Shieldwolf:
hmm starting over with the zinc wrapper
