Main > Software Forum
mamewah list error
Minwah:
BTodd: are you running Win98?
I wonder if this is a '98 specific problem, possibly related to another error (usually Run Time 75)...I posted a fix for that one which might work...hold on while I try to find it...
Minwah:
OK try this:
Make a batch file which does something like (substitute your mame path etc.):
c:
cd\mame
mame > temp
exit
Then run the batch file *before* MAMEWAH for the first time after boot-up.
If it doesn't work 1st time, delete the contents of the \Files folder, reboot and try again. Please let me know how it goes...
btoddkelley:
I am using XP. I concluded it was a problem with analog mame in my case. Once i switched to regular mame it worked fine. When a new Analog mame is released I will try it again.
Todd
Minwah:
--- Quote from: btoddkelley on May 18, 2004, 10:51:45 am ---I am using XP. I concluded it was a problem with analog mame in my case. Once i switched to regular mame it worked fine. When a new Analog mame is released I will try it again.
That's pretty odd. I take it Analog MAME's -listinfo (& other 'standard' switches) work the same as regular MAME?
moloch:
I was just going to edit my autoexec.bat to start mamewah. I do not know how to just make a batch file. I am guessing that I just make a ".bat" file out of notepad with your instructions and have autoexec.bat call it during boot.
I saw mamewah running on an old machine at my work and I now know what it should look like, and I never got it to run on either of the two machines that I have tried. I just got a blank white screen.
