Author Topic: Suggestions for minimum buttons  (Read 1149 times)
MameMe
  • Last login:June 08, 2005, 06:45:25 am
« on: May 01, 2004, 07:12:52 am »
Basically I've decided to go with 3 controllers on my control panel.  The two on each end will more likely be T-Sticks and the middle will be a WICO 4-way.
The WICO dedicated 4-way is when I play alone which will be 90% of the time on games like pacman, mspacman, maybe track n field.  The end sticks will be when nephews come over 10% of t he time and we play fighting games like SF & MK.
The thing I can't decide on is how many buttons I should have for each controller.  From what I gather 6 buttons are minimum for fighter games right?  How about those 4 way games, are 3-4 buttons enough...too much?  I know I don't want 7 buttons on the ends, and to be honest I don't want 6 unless they are absolutely needed for most games.
I guess I just need some advice from your experiences.  Thanks group.
Tiger-Heli
    • Tiger-Heli
Re:Suggestions for minimum buttons
« Reply #1 on: May 01, 2004, 10:49:27 am »
I think you want six on the ends for fighter games.
Question 1 is - for alternating 8-way games (Gyruss, Timepilot, I assume you intend to use the end joystick?)  (I will assume so)
For the 4-way - the next question is "Would I be comfortable using some of the other players buttons for these games?".
If so, you don't need any buttons.
If not, it's a rapid case of diminishing returns -
0 buttons - Pacman series, others
1 button - DonkeyKong series,Galaga,Galaxian.  (lots of 8-way games, but I won't include them).
2 buttons - don't really know of any, there probably were 1 or 2, lots of alternating 8-way games, but . . .)
3 buttons - only ones I know of were 8-way
4 buttons - probably too many
Lilwolf
« Reply #2 on: May 01, 2004, 12:43:36 pm »
As for a dedicated 4way... I have a wico leaf and would recommend the extra money for a happs mspacman reunion stick.  The have a smaller throw and feel better in my opinion.
Next..
are you worried about realistate or number of inputs in a keyboard encoder or price per button?
why?  You can easily have the 4way and the 4way buttons use the same inputs as the first player (but a ground cutoff switch is nice to remove the ability of the second player to grab the stick to mess up your super upper cut when they are dizzy).
MameMe
« Reply #3 on: May 01, 2004, 03:25:05 pm »
Tiger-Heli..so from what you said I think I might only need 1 button for that 4-way in the middle then.  Only because I don't play too many other games that use more than 1 button.  If I do though, I can use the Player 1 joystick & 6 buttons to play pretty much anything.
Instead of using another players buttons I guess I could use Player 1 buttons like suggested.
LilWolf..I am worried about realestate as I don't want a crowded control panel.  I think I can connect the 4-way & the player 1 joystick to some of the same connections on an I-Pac.  So no I'm not worried about that.
Does 1 button for the 4-way & 6 for the end joysticks sound reasonable then?
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: May 01, 2004, 03:34:14 pm »
I think you will be okay with 1 button.  And you don't need that, but it might be more obvious how to play than having to use P1B1.
Personally, I like 7 button layouts like the HotRod SE (even if some are duplicates so only six inputs), to allow for easy Neo-Geo games, but if you never play those - - -
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #5 on: May 01, 2004, 04:45:42 pm »
Don't forget Stargate and Defender... those require 6 or 7 buttons...
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: May 01, 2004, 05:01:09 pm »
Not really, Stargate needs six, but it's a two-way joystick, not 4-way, so I would use the P1 controls to play it.  Also it's alternating, so you could use both the P1 and P2 buttons for it, depending on the layout.
paigeoliver
  • Awesome face!
« Reply #7 on: May 01, 2004, 05:16:31 pm »
Real minimum number of buttons is 4.
Little kids will truthfully have just as much fun with the 4 button Neo Geo fighters as they will with the 6 button Capcom ones. I usually put 4-buttons on cabinets that I build for other people, and just leave the capcom fighters off.
MameMe
« Reply #8 on: May 03, 2004, 12:08:58 pm »
I'm so Indecisive  >:( it makes me mad.   I've had an x-arcade solo for a month now and I haven't used more than 4 buttons.  Even when I play fighter games like MK or SF.  I'm not a hard-core fighter gamer unless its QuakeIII but that's another forum.  ;)
Although... I like the way 6 buttons look on a CP, and I doubt I'll ever use them all.
If I ever decide I'll remember to post it here.  :D
