Main > Software Forum
25KHz + Games List
jerryjanis:
--- Quote from: rchadd on April 28, 2004, 06:32:21 pm ---i think the monitor needs to be physically able to display the extra pixels that higher resolution games have.
Correct. The image can be displayed by either skipping some lines, or by interlacing, but either way it looks a lot better on the right monitor.
Here's a list of horizontal games with a y resolution over 300:
http://jstookey.com/arcade/sortinfo/index.php?num_switches=2&do_search=1&switch0=y&operator0=%3E&switchvalue0=292&boolean0=AND&switch1=orientation&operator1=%3D&switchvalue1=horizontal
rchadd:
the list seems pretty long to me :(
can you display some of these games on std res monitor using ArcadeVGA by enabling interlacing?
jerryjanis:
--- Quote from: rchadd on April 29, 2004, 06:14:09 am ---the list seems pretty long to me :(
Have you seen the list of games that fit in the opposite category? (holy moly!) ;D
--- Quote ---can you display some of these games on std res monitor using ArcadeVGA by enabling interlacing?
Absolutely. All of these games will play fine with the ArcadeVGA in interlaced mode. The flaw is that it's interlaced which isn't perfect (because of the slight flicker to the screen) compared to using the proper monitor.
