Author Topic: USB Steering Wheel  (Read 1577 times)
buck3480
  • Last login:August 28, 2007, 03:41:14 pm
  • I'm a newbie
USB Steering Wheel
« on: April 26, 2004, 03:11:22 pm »
I hope this hasn't been asked recently, but is it possible to get a steering wheel that plugs into my USB port to work in MAME with games like Spy Hunter?  And if so, what do I do?  I have a wheel setup and working in for PC driving games, but I don't know what to do to get it to work in MAME.  I think I'm running MAME .69 (I can't remember) and I'm running XP with Mamewah.
Re:USB Steering Wheel
« Reply #1 on: April 26, 2004, 03:14:06 pm »
Yes, simply enable joystick input: 'joystick 1' in your MAME ini file, or have a look in the menu's for MAME32 :)
buck3480
  • I'm a newbie
« Reply #2 on: April 27, 2004, 09:39:44 am »
Thank you.  And thanks for a great front-end  :)
zudmsc
  • Last login:September 07, 2011, 07:44:26 am
Re: USB Steering Wheel
« Reply #3 on: August 04, 2006, 10:33:14 pm »
where is the mame ini file?  I am not using a front end.
Zud
JONTHEBOMB
  • Last login:October 20, 2019, 12:08:18 am
  • BOOM!!!!
« Reply #4 on: August 04, 2006, 10:43:26 pm »
This site will help you: http://www.mameworld.net/easyemu/mameguide/mameindex.htm
Go to Mame Win32 Setup on the left hand side.
zudmsc
« Reply #5 on: August 04, 2006, 10:46:16 pm »
dos it matter that my rom set is .62  ??
JONTHEBOMB
  • BOOM!!!!
« Reply #6 on: August 04, 2006, 10:54:33 pm »
No, it doesn't matter what rom set you have.  The instructions on the site will allow you to create a mame ini file.  Where you may run into trouble with the .62 rom set is if your version of Mame is different then the rom set, some games may not work or may not work well.
zudmsc
« Reply #7 on: August 04, 2006, 10:57:32 pm »
ok, the games do not work.  They work on my dos .62 mame, nut not this new mame32.107
JONTHEBOMB
  • BOOM!!!!
« Reply #8 on: August 04, 2006, 11:07:55 pm »
You can find old versions of Mame here:
http://www.mame.net/oldmame.html
You can find old versions of Mame32 here:
http://www.joymonkey.com/main/index.php?n=MAME32Archives.060To069
