Main > Main Forum
Control Panel for 1981 Qix Machine.
Pages: << < (3/3)
mllkat:
 :) You guys ROCK!! I appreciate all the input. Let's just see now if I can get the job done. Thanks again for your suggestions.
Mllkat
dogg0:
--- Quote from: Apollo on April 25, 2004, 08:06:38 pm ---I would suggest you don't mutilate that CP but that you get a sheet metal business to make you a blank copy of the panel, have it drilled ( you could do that yourself ) and the powder coat it. Then just SF layout should fit fine.
do you know of any online sheet metal places? or what to look for in the yellow pages? or what to ask when you find them? I have a 1981 Scramble machine that I need to put a new cp in. thanks.
Stingray:
--- Quote from: dogg0 on April 27, 2004, 03:46:29 pm ---
Look under Metal fabricators. Take your old panel in and have them replicate it. They can also punch holes where ever you like.
-S
Lance:
I would just build one out of wood.  My friend has a taito cab that we are working on and it you will save yourself a lot of effort if you just make a wood (mdf) panel.  The clips that hold the panel down are bolted on to the metal panel so it would be easy enough to just do the same on a wood panel.
hyiu:
I think mine is an old 24 in cab... so the CP is just like 22.5 in or so....
http://geocities.com/hyiu/pics/Arcade/Cab_and_Stick/
you can check out the link, and click on the pics...
it was a metal panel, and I redo it with wood... and actually have enough space below to have a keyboard drawer... (but its tight....)
so... it should fit 2 player SF style....
good luck...
Pages: << < (3/3)
Go to full version
