Main > Main Forum
Control Panel Plans
Pages: << < (3/3)
depressd:
Question, I did a quick "sketchup" No pun intended  :P
These are the happs ultimate measurements. The inner circle is the button, next is the drill hole, and the last is the edge of the button. The 1 1/2" length from the center doesn't appear to be right. Did I do something wrong there?
TalkingOctopus:
hmm... Go get this template: http://webpages.charter.net/rbecker5/files/joy.doc Print it.  Measure the space between the button centers.  I would measure the space on my actual machine but I do not have access to it at the moment  :'(.  I don't even have a ruler!
depressd:
Nevermind, I believe that measurement is representing the radius of the distance and not the true length. If I measure from the edge out 1/2 to 3/4 to the next edge. It is represented correctly.
depressd:
Has anybody used this type of button layout? Do you like it?
flampoo:
The most important question is, "do you like it?" It doesn't look too functional, though. It's a skewed SFII layout. But if it works for you, go with it.
Pages: << < (3/3)
Go to full version
