Author Topic: Rotary T-Stik Plus? DEFINITELY!!! (UPDATE: 6-3-04)  (Read 2536 times)
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« on: April 22, 2004, 05:05:00 pm »
(UPDATE: 6-3-04)(Please note: I figured it out, here's the How-To: http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=20018
Would it be possible to add/hack a rotary function (optical?) to a T-Stik Plus?
If it's even feasible, it might not be ideal, but I'd LOVE to have an all-in-one solution for 4-way/8-way/rotary games. I love Ikari, etc.. but I just can't justify the extra room on the CP.
« Last Edit: June 03, 2004, 01:16:20 am by mr.Curmudgeon »
GGKoul
  • Cheesecake Apprentice
Re:Rotary T-Stik Plus?
« Reply #1 on: April 22, 2004, 07:28:44 pm »
I don't think you would be able hack a T-Slik to a rotary.
Make your panel modular.  As that will probably be the best way to add everything your looking for.
Search the forum, as this was discussed last week.
-GGKoul
« Reply #2 on: April 23, 2004, 09:19:53 am »
I don't think it's gonna happen...the shaft would have to be longer for the encoder wheel to attach to.  Probably more hassle than it's worth even trying  :(
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #3 on: April 23, 2004, 10:12:11 am »
After seeing how the wico rotaries are made I think it would be possible.  The wicos are a mechanical rotary joystick, they have a 12 position switch that is held in place with a bracket.  I don't have any pictures since I sold the ones I had already but bet you could hack something together.
mr.Curmudgeon
  • Huzzah!
« Reply #4 on: April 23, 2004, 11:50:40 am »
Thanks for pointing out the Wicos. I'm off to find pictures.
I've seen a lot of things on this board that people said couldn't be done...and just as many things (if not more) that were not worth the hassle, so you never know.
I'm not giving up just yet.
mr.Curmudgeon
  • Huzzah!
« Reply #5 on: April 23, 2004, 11:55:11 am »
Here's a guy that hack an Ultimate and created his own rotary. Don't know if it applies to my quest, but it's interesting enough.
http://www.vm68.com/macstick2/
« Reply #6 on: April 23, 2004, 12:10:12 pm »
Very true!  If you do manage it, be sure to post a how-to :)
Aceldamor
« Reply #7 on: April 23, 2004, 04:30:50 pm »
Not a bad little hack...but I imagine the spin would be rather "Loose" since there isn't any kind of restrictor that would keep it from spinning
Fuzzy Wuzzy was a woman!
mr.Curmudgeon
  • Huzzah!
« Last Edit: June 10, 2004, 12:26:55 pm by mr.Curmudgeon »
mr.Curmudgeon
  • Huzzah!
Re:Rotary T-Stik Plus? DEFINITELY!!! (UPDATE: 6-3-04)
« Reply #9 on: June 03, 2004, 09:20:21 pm »
Be sure to check out the videos too, for full-motion rotary goodness!   ::)
