Main > Main Forum
Schematic: Basic AC Arcade PC Wiring
Pages: << < (3/3)
SirPeale:
I'll have to take some pictures when I finally get everything the way I want it.
GamingGreg:
--- Quote from: Peale on April 22, 2004, 08:35:01 am ---With this setup, it has eliminated the need for a power strip.  Everything is already controlled from one switch, just flick it on and you're up and running!
What about surge protection?  My understanding is that the filter in the diagram only handles interference, but not large spikes.  Is that right?  I guess you could always put a surge protector between your home power and this circuit.
SirPeale:
I believe that's what the fuse is for.  You get a surge, fuse blows, not the computer.
GamingGreg:
--- Quote from: Peale on April 22, 2004, 02:09:28 pm ---I believe that's what the fuse is for.  You get a surge, fuse blows, not the computer.
Makes sense, as long as the fuse is small enough.
SirPeale:
Wow...can't believe I did that a year ago.  Seems like yesterday.
Pages: << < (3/3)
Go to full version
