Author Topic: leaf button question  (Read 626 times)
nomad
  • Last login:March 31, 2007, 04:15:28 pm
« on: April 21, 2004, 07:03:46 pm »
For my metal control panel, I would like to have some translucent leaf buttons.  However, I have seen that only "short" leaf buttons mount easily to a metal cp.  I would like to use some colors the come only in the long variant.  On Bob Roberts' site, I noticed that he says that one can mount "long" buttons using spacers.  I am just wondering where you could obtain the spacers or if you could make them out of pvc piping or something?
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re:leaf button question
« Reply #1 on: April 21, 2004, 08:02:02 pm »
Evidently, certain suppliers provide spacers, but mine did not.
I was using short buttons on wood and only needed to use washers as a spacer. For you, PVC would work well.
saint ganked my avatar.
nomad
« Reply #2 on: April 22, 2004, 03:37:20 pm »
Thanks.  I have another question too.  On Wico's site there are two different leaf holders.  One has tungston thing on the switch and the other has some other material.  Does it make a difference which holder I purchase?
paigeoliver
  • Awesome face!
« Reply #3 on: April 22, 2004, 04:11:29 pm »
You aren't really going to wear out any new leaf switches in home use, so even the cheaper ones should be fine. Heck, I regularly install 20+ year old ones in games, and even those are fine.
nomad
« Reply #4 on: April 22, 2004, 07:03:07 pm »
Thanks for the advice :), but I have one more n00b question for your guys.  For leaf buttons, I noticed that you must have the button holder assembly, leaf switch, button, and a pal nut.  On Wico's site however, there is this item called a distance washer.  Is that thing just a spacer so that one could put long buttons in a metal cp, or does it serve some other function?
FractalWalk
  • Newbie
« Reply #5 on: April 23, 2004, 06:08:35 pm »
I'm not sure what that is. As a spacer it is pretty thin. If I had a metal panel I would have needed about 5 of those per button.
