Main > Project Announcements
New Project - Galaxian Conversion
AlanS17:
Good job on the machine. It looks good that way. I have a Galaxian in similar disrepair, but I'm gonna (hopefully) be converting it to a Galaga. Mine has sideart hiding under sheets of yellow formica. I'm pretty much already chalking it up to a loss.
I'll likely have to replace the monitor. Last time I played it (when I got it to test it out), I smelled something burning and then I lost picture.
Either way, I won an auction on Ebay a long while back for a working original Galaga board and full reproduction sideart (sides, front, and CP) for something like $350. As soon as this broken finger heals, I'm gonna try to get that up and running. I've got 14 machines taking up space in the garage that I need to restore and push out.
SirPeale:
Issue: no red showing on monitor:
Finding: poor solder joints on neckboard, particularly on the tube socket.
Repair: reflow/add solder to joints on socket. Works much better now.
SirPeale:
Not done - never done, of course.
I had it outside on my porch for Halloween. One kid said that our house was the coolest house he'd ever been to in his ten years of trick-or-treating.
Today we re-arranged the house. I said "hey, let's bring the cabinet into the house" and suprisingly the wife agreed.
Luckily, I have a hand truck. A really good one. Unfortunately it's solid steel, not aluminum, so it adds a ton of weight to whatever you're moving. When you're on a flat surface, it's not that big a deal. But when you're trying to move it upstairs with your not-so-strong wife...
Luckily it made the journey intact. Almost didn't, I thought she was going to lose it.
Keyboard hack got bounced around a bit, one wire came off. Quick touchup with the soldering iron put that to rights.
Still need to do a little tweaking in software. Lock down ArcadeOS and get a few more games in there that will run on the hardware I have in the cabinet and with the controls that I have.
One idea I have is getting some translucent leaf buttons for the P1 and P2 and getting the LiteMite. They'll blink in Galaga/Galaxian, and that would be cool. Would also be relatively inexpensive.
SirPeale:
I never took pictures of the inside. Find some here:
http://www.pealefamily.net/tech/arcade/?p=363
saleem:
--- Quote from: SirPeale on May 01, 2005, 07:40:34 pm ---Still need to polyurethane the sides and front.
would you recommend polyurethene for putting the shine to paint.
i wet sanded a cab,so now its all hazy,its smooth as hell!but,hazy.i need to put the shine back once i have prep'd the paint by cleaning residue of it.so would it do to give me a lovey smooth shine?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
